sierra cosworth power upgrade
my car at the moment is running a stage 1 if i added greens 3 bar map sensor and a chip running on a t3 what gains would i see and what would it cost is it worth doing.and its a 2wd
£500/600 would get everything with a brand new chip...
But you will need a breather kit for stage 3 and a rolling road tune
Look in parts for sale and get
Greens
3 bar mapp sensor
Breather kit
And a decent cooler
And get a new chip too suit and also check the fuel pump wiring and the voltage because they cause problems too
320bhp t3 and will drive really nice
Greens
3 bar mapp sensor
Breather kit
And a decent cooler
I would consider a nms gunship either on std injectors or greens, add a 4x4 or rs500 cooler. If you go greens will need 3 bar map, both will give a good increase over stage 1 chip.
Greens
3 bar mapp sensor
Breather kit
And a decent cooler
Greens
3 bar mapp sensor
Breather kit
And a decent cooler
Greens,4x4 cooler,-34 actuator,grp A coil and a 3 bar map sensor is how they should of rolled off the production line imo.Perfectly drivable,reasonably good on fuel and well within the limits of what the engine will take.@ 22psi on the T3 it will be quick enough and then once used to that,change it all again
big floppy donkey dick
i wouldnt put any more boost and ignition on an unhealthy engine, do the usual compression test and oil pressure checks before you give it 60% more power lol
but yes, stage 3 is how a cossie should be, all day
charliecosworth
19-08-2015 02:00 PM
155lee
14-08-2015 11:21 AM
