Omex related problem HELP!!!
#41
1st to 200 without NOS
Yes some engines do manage without idle valves but most run better during warm up with one, whenever we fit Omex or any aftermarket management for that matter I always recommend having an idle valve. Throttle body set ups normally manage well without them though.
#42
The problem is the smoke and can this be down to the idle valve? What else does this valve do???
They put a base map on the car and all u can smell is petrol from the exhaust but blue smoke and they are certain it isn't management
#44
Just want to see if it is simple to do or something obvious. I will be needing an omex specialist to set it up and the cost will be going straight to the first garage who f'd it up!!!!
