AP Racing cosworth clutch pedal weight?
Hi,
I am considering weather or not to go to hydraulic clutch conversion on my YB powered Mk1 escort. I have used uprated clutches before, however only with organic linings.
The question is, what is the pedal "weight" like on the ap racing "sprung" six padel clutch as sold by the likes of burton power/reyland etc??..
Is this managable in normal driving, Would like to hear from people that have "used this specific clutch" with a cable please..
cossie fan (unluckerly)
im going to hydraulic mine soon as im going through the hole car uprateing bits before i go for more power but to be honest the ap on a cable clutch isent to bad and has never really bothered me!
Does any one know the the weight of the cover in pounds etc? . I hered an uprated cvh one was around 1600lb once i think ?..
I don't mind changing the cables every 2/3 years if need be. I know they don't last !!.
Is the pedal weight much more heavy than a stand one?
Carbon Crazy
cocyhn it will still be a bitch to pull away as its the nature of a clutch with little slip, but at least youll be able to control it easier with hydraulic.
Plus when you get out the car after driving in heavy traffic you will walk in a straight line rather than in circles
1 Post
Ah I don't mind that now, I can a rugby at least twice the distance with my left leg now
I need to drive one with the same setup, but at the mo it doesn't really bother me that much
They should be able to tell you the clamping pressure of the pressure plate you are to purchase. In NZ you can get the pressure plates uprated (change pivot point of fingers) i first tried 2300lbs very heavy but am now using 2100lbs squeeze daily on a cable clutch which is alot better. I have got used to it but jump back into a japper and you almost punch the clutch pedal through the floor!! i would go over 1900lbs next time, he measured a std cossie pressure plate for me which was 1700lbs to start with.
Kev
Kev
ive got an ap 6 paddle clutch to go in my saph - but when i had my 3dr i tried a couple of cars with the ap 6 paddle and the alcon 6 paddle clutches fitted - the alcon had a much lighter pedal feel so i went with that in my 3dr and never had any issues.
I need a light pedal as have had two knee ops on my left leg
formerly beefy-rst-2
just been looking at these on the bay ,
not sure if there specific to size ect ,
but looks the same as the burton kits ?
http://www.ebay.co.uk/itm/2509286558...84.m1423.l2649
Carbon Crazy
BTTT for part numbers. Someone must know. Cant imagine it's only traders that know this info by now so i dont get all the secrecy. You hear a lot on here how cheap it is to do without buying a kit or how you can get centre push easily too yet noone shares the details. Strange.
Whats the weight of your flywheels chaps any ideas ?
I have this set up in my MKII Cosworth Escort:
T5 Burton Hydraulic Conversion
AP 6 Paddle Clutch - bought from Burton
AP Pressure Plate - bought from Matt Lewis
Only problem is my car isn't finish quite yet so won't be able to tell you if its OK !!!!???!!!!
If you need part numbers let me know.
both that are needed its easy to find them on ebay its all i did look at pics an match them
just exsample
http://www.ebay.co.uk/itm/BMW-new-cl...item27c481e3c1
http://www.ebay.co.uk/itm/Land-Rover...item23197d1b36
just exsample
track.focus'd
12-08-2015 05:53 PM
