View Poll Results: use a repaired block or not
Voters: 22. You may not vote on this poll
cracked blocks
cracked blocks
would you use a Cossie block that has been repaired(by a well known engineering firm)it's been welded across two of the head bolts threads it's been offered to me for cheap money it's fully rebuilt to standard spec! will only be used to 300bhp max(so not too much flexing) as it's to go in a Ford Anglia project
You think a crack along 2 head bolt hoes is bad...
http://www.turbomustangs.com/forums/...&postid=358815
