fao pj motorsport
fao pj motorsport
hi paul just a quick qeuery and if you could help i would be eternally gratefull, i have bought a car with one of you engine rebuild in it,
the engine was built on the 23.07.01, the customer was joe bird, the car was a black 92 saff 4x4 reg num J644 AVX ,and the invoice number was 2738, i'm getting my car all sorted and mapped but when you have done your invoice under pistons used , it just says pistons......£499.95, the question is can you tell me what type of pistons these were from you records??? or do you know from the time/price they were purchased what type they are likely to have been.
P.S. YOUR ENGINE BUILD IS FAULTLESS AND THE ENGINE STILL SOUNDS AND PERFORMS PERFECTLY, A TESTAMENT TO YOUR ABILITYS, TOP JOB MATE
cheers carl
cheers carl
cheers paul for the reply mate, much appreciated, i take it by saying there mahle thats standard compresion ratio etc yeah???
once again paul thanks for the reply and comments mate
carl
carl
A lot of big engines uses Mahles matey
hmm, so i'm nearly there with what they are, wonder if paul can identify them a little more with regards to c/r from his records, heres hoping
Although to be fair your talking about an engine thats nearly 4 years old this year so the build sheet might be a tad bit difficult to find
If you post the current spec then an rough idea of CR can be gathered from that
dunno what the spec is other than it was built by paul and at the time he made it stg 3, performance parts used during the build that ive picked out from the list include
200 block rebored to +1.0mm
piston set
grp a engine gasket set
motorsport cambelt
head recondition inc bronze guides
1 x a.bayjoo chip and board
1 x 3 bar
4 x 803's
theres a huge list of stuff used but those are the performance bits in the list so make of that what you will
piston set
motorsport cambelt
1 x 3 bar
4 x 803's
bugger that means i cant run that much boost then dont it?
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
