ahmed bayjoo springs
Post Miester !
I have got them on my cossie, They are really good, they are best matched with Koni Shocks, Gives you the best of both great handling and a quality ride
Its also worth adding a front and rear strut brace, also a 4x4 Anti Roll bar..
He only does them in standard height tho..
Give him a call on 07885 144 422
Al...
Al...
Originally Posted by M7 COS
I was told Bayjoo springs are the same as Leda springs, don't know how true that is though! Probably a load of crap!
Post Miester !
Yes they are, but the poundage/rate etc, is best matched to a Koni shock.
However...
My Mate GurnE is breaking his car at the mo, he has a set of Brand new not fitted -25mm Eibach springs for sale,
They are great quality, they also give good handling, just a bit stiffer.
https://passionford.com/forum/viewtopic.php?t=102357
Al...
However...
Al...
I used to have Leda springs, and I thought they were brilliant!
Mat,
Ahmed's springs are £20 cheaper than what I quoted you for the Eibachs. I can supply these as well.
Just be aware that 4x4 springs are different to 2wd ones...
How much is this Ahmed set for Escos? Would this be much higher then my setup?
How do you mean higher?
Are you referring to ride height or spring rate?
I heard the Bayjoo springs for the Escort Cosworth make the rear of the car sit lower than standard.
I mean car height - my car is far too low for Polish roads. If there was nearly standard height spring avalible cheap then maybe I schould buy it before I save for coilovers?
I had a set of Ahmed springs on my S2 - they were std ride height and matched to Koni's. Handled very well indeed and soooo much more comfortable than the -25mm springs I had on.
SMILER258
28-09-2015 09:04 AM
truffleshuffle
10-09-2015 09:35 PM
