FAO - AP brake guru's
I have a couple of questions regarding some AP calipers i am looking at buying
They are for the rear of my fiesta,
The calipers in question are the CP5040-4S4 & CP5040-5S4 leading variety that are to suit 315mm or 330mm x 28mm thick disc
http://www.apracing.com/info/product...tres_2679_2678
The question i want to know is can i use a disc in between those 2 sizes stated as i have some 325mm x 28mm discs that are perfect and give me enough clearance for what i need so i want to stick with them? i assume as it is between the 2 it will be fine?
Also the other question is what pad would you recommend for the rear set up?
I don't want a really good pad for the rear if that makes sense as it would be better if the performance is less than the front which will be using AP 6 pots fitted with the DS2500 most likely
Any help and info appreciated
Thanks
Marc
Thanks
Marc
