differences from xr4x4 and cosworth rear hubs
hay all, will cossy rear hubs go on the xr4x4 rear,do you need to change the shafts etc,or can you just change the hubs (bearing carriers) etc
merry christmas all
merry christmas all
The bearing carrier has longer lugs to mount the calipers onto due to larger disc. The stub shaft and flange from the 4x4 cosworth are the same as the xr. The 2wd cosworth has a different stub shaft due to a larger cv joint.
ah i c so the 4x4 cozzy is the same as the xr apart from the hubs,so i should be able to change the hubs but keep all my shafts etc the same
ah good stuff ive got 4x4 vented calipers going on 300mm discs on the back but i need the cozzy hub carriers ,thought i was going to have to change the lot lol
jessie_rs
11
03-06-2019 04:57 PM
track.focus'd
12-08-2015 05:53 PM
