Escort van engine swap. Powersteering question
Im another engine in my escort 55 diesel 2001 van. The engine from the other van didn't have power steering. Can it be put from the engine coming out onto the one that didn't have it?
Lucifer II - 666
The rack will fit yes quite simple and your subframe should have the mounting points for it already.
Your only issue will be with whatever the new engine is? If it's like for like it'll all swap over easy.
If you're converting to Petrol engine from Deisel obviously the pumps and pipes will all be different and you'll need to fit those to.
