Need help desperate on my rs, wont run
I brought my rs turbo yestetday ran fine took it out today after 2 mile at sitting at 60 mph car started spluttering, I thourt it may have blown a plug as its been sitting a while its just had new plugs new dissy and rotor arm, tried start it and it turned over for a good while then back fired, tried again and it ran but was still running rough, left it a bit went start it agin and wouldnt start and backfired again, so iv left it now but any one got any ideas?
Sitting 5 year fresh fuel, and just a new cap not full dissy, although timing is adjusted as standard marks dont line up in dissy, but like I say ran fine yesterday iv checked all the fuses,
Also when I start the car it turns over realky slow and sometime stops turning, but then sometimes it starts ok, battery is new, but starter looks really old could the starter be seizing?
Will give it a go tomorrow, hope its something simple, car ran fine for 50 mile, I will be geting it set up before I use it but ideally want it running like it was yesterday so I can get it to a tuner
st170 breaking
disconnect the cold start (injector goes into the plenum from the underside will prob be blue plug)
if that doesnt help hold down the meterhead flap a bit to see if it starts
if theres fuel when you crack off the 11mm banjos on the meterhead you know fuel pump and reg is fine so you can crack off the injectors next
fuel gets to the meterhead but not always the rest of the way due to the flap and mech being gay
Thanks, ill give these ideas a go tomorrow
Right iv took some advice cleaned metering unit, and checked dissy timing car now starts first turn of the key, but is not fireing on no 1, iv got a new plug in and there is a spark at no 1, what should I check next?
then see if the spark plug is getting wet, if it is then next step to me would be compression test, you have spark and fuel, so compression next,rings/valves/gasket testing if it ain't the injector blocked
Ok ill check the fuek pipe, hope it is just fuel only dun 50 mile in the car and that was at 60 mph and zero boost as its desperate for a set up
Right iv got fuel and spark at the plug, so goin av wait for my mate di a compression test tomorrow, just what I need, more expense when iv only had it 2 days
the driving it 60 miles might have done more harm than good with it sitting so long
comp/leakdown test will tell
in all fairness I've had an RST with the metering head and it was a pain in the tits, like the guys on here said better swapping it to efi if its a project, it can rule out a lot of annoying faults
right just done a compression test and iv only got a bit over 70 psi on piston 1 compared to over 140 on the other 3, aparently next i need do another test to see if its valves or rings? if this sounds right? all new to me
well if you put a few squirts of some engine oil down the plug hole then redo compression test, if it goes up on first few cranks then its the rings, as the oil helps provide a temporary seal on the rings against the bore's walls....if it don't go up then its probably a head off job to look at the valves/check gasket to figure out whats up...unless you know someone with a leakdown tester....but chances are the heads still gonna need to come of either way imo.
Zee Germans are coming
if your looking at a rebuild i have a fez turbo bottom end sitting in the garage so perfect for goimg efi
100 quid for it but it will need a freshen up
Eigdoog
13-09-2015 05:46 AM
