rwd conversion
Old Dec 2, 2011 | 01:26 PM
jutty19's Avatar
jutty19
Cool rwd conversion
is it possibly to use a fwd 1.6 focus engine for rwd conversion.
Old Dec 2, 2011 | 01:34 PM
R4N SS's Avatar
R4N SS
anything is possible with enough budget mate
Old Dec 2, 2011 | 01:37 PM
jutty19's Avatar
jutty19
what engine would be gd for a rwd mk4 escort
Old Dec 2, 2011 | 01:38 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
The engine is the easy bit, its getting the transmission and steering working you want to worry about mate!
Old Dec 2, 2011 | 01:41 PM
jutty19's Avatar
jutty19
so i could get a 1.6 focus engine and what transmission is right
Old Dec 2, 2011 | 01:42 PM
Chip's Avatar
Chip
You need the rear end from something rwd to be grafted into the back of your car, then you can bolt up a type 9 gearbox to the 1.6 focus engine if you want
Like I said though, the engine is the easy bit, its like asking what wing mirrors should you use.
Old Dec 2, 2011 | 01:48 PM
jutty19's Avatar
jutty19
cheers thats a big help
Old Dec 3, 2011 | 02:34 AM
bj928's Avatar
bj928
rwd focus is fun, would love to do one myself, kugel komponents do a bolt in kit to convert a focus to rwd, not to bad on price either, i took their red focus out for a test drive, it did pull well, but then it should wth a 420hp 5.0 v8, here is a british one though having some fun, maybe even a member on here.
http://www.youtube.com/watch?v=y6c02XQwk3c
Old Dec 3, 2011 | 02:01 PM
OrionHayden's Avatar
OrionHayden
Ford mad
no point going for 1.6 focus engine, go for either a well specd pinto on 45's if you can afford it or a 2.0 zetec on either bike carbs or 45s
Old Dec 3, 2011 | 04:14 PM
JoeE30's Avatar
JoeE30
I like that focus.
Old Dec 3, 2011 | 04:50 PM
gouch1's Avatar
gouch1
Old Dec 4, 2011 | 10:53 AM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
the weight advantage of the sigma 1.6 over the pig iron pinto is a no brainer, same power give or take after its been tuned with carbs/ITB`s etc in my oppinion,
or going to that extent then a 1700 pump lump is same job to fit, plenty plenty RWD stuff on the market as the kit car brigade LOVE these engines, checp, readily available and VERY VERY tuneable!
Sean.
Old Dec 4, 2011 | 11:33 AM
gjh's Avatar
gjh
Personaly I wouldn't bother with the 1.6, by the time you tune it up to a lightly tuned 2.0 sort of power level it'll cost loads and will be fairly highly strung.
Old Dec 4, 2011 | 11:35 AM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
No it won't, set of SS4 cams, full exhuast, Shawspeed HD bottom end bolts if you want to raise the rev limit, and a re-map and you're looking at 140-150bhp, and it won't be hightly strung, know loads running that power daily! Mine will be soon.
Orrr, you can make a tubo manifold, stick a T25 on, and a de-comp plate and run 200-ish bhp happily. Ollie Clarke ran a turbo'd 1.6 in time attack for a year and gave it death, and it's still running now in a customers car!
Old Dec 4, 2011 | 02:33 PM
Chip's Avatar
Chip
Carbs?
It is 1975 again already?
You started off so well with the "no point going for a 1.6 focus engine" bit and then you just went epically downhill from there with the stupidest suggestions ever
Old Dec 4, 2011 | 02:35 PM
Chip's Avatar
Chip
With regards to the 1.6
Neil roper head, set of michael woodford cams, set of bodies and some pocketed pistons, gave over 170bhp on one I mapped recently, but no torque at all, RWD focus needs 300bhp to be worth building IMHO, preferably a lot more, Ians was spot on with 450
Old Dec 4, 2011 | 03:33 PM
01dwilkinson's Avatar
01dwilkinson
Mk3 capri 3.0l
Default rwd
It probably wouldnt be worth fitting the 1.6 after going to the effort of doing the conversion. Maybe think about something with a higher output and more tuning ability. Cosworth engine ect. Also best to try and plan ahead and make sure you have room for certain components. At the end of the day though it is your car and you can put whatever you want in it.
Old Dec 4, 2011 | 06:15 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Just buy a 2litre zetec and turbo it if you're really serious about RWD'ing the escort.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
