Garrett Intercooler Cores
Docking, Pace, A&H, Radtec and no doubt others can supply intercooler cores to pretty much any shape or size you need.
It'd need to be something either very bloody special or very keenly priced to warrant buying from the US. And given the crap exchange rate I cant imagine that happening.
Designer/Fabricator
Makes the exchange rate look cheap
![Smile](https://passionford.com/forum/images/smilies/icon_smile.gif)
Pace were the cheapest, although not in the exact size I wanted.
But Docking also werent even close to the most expensive. They were in the middle really.
Happily retired
Intercoolers its the efficiency of the core that matters (bar & plate at this price level) not size . I did the research on this 2 years back. If you want to pay 10k for an intercooler then there are some incredible core out there used in other industries. Make your limit £800 the bar & plate from Garrett is the most efficient thats a fact not a debate or i would have gone elsewhere. The difference a smaller but more efficient intercooler made to mine is quite rermarkable & with efficiency comes flow & more Power. People think keeping CA down is all an intercooler does if correctly designed it will make Power as well .
With the new core, temps did drop dramatically. Although it was much bigger in every respect.
And an IC core's primary task is of course to cool the air. The only other thing it has to do, is cool the air without posing a restriction. It's a pretty easy task if as you say the core is efficient enough to do so given the space available to install it.
Rod its exactly that reasoning which is why I want a Garrett core. Enough mags have done enough tetst now to show that the Garrett cores are the way to go.
Iv narrowed my search down to the choice of two cores from they're range, one rated at 425 the other at 475 (im aiming for 400 but would accept 380hp) the deciding factor for me will be how well each of them fit in the space I have for them on my Corsa.
I do hope they dont rate their cores only by HP ? That makes no sense whatsoever. A lot of Yank companies do that !!
The airflow and more importantly cooling requirements for two 500bhp engines will be very different.
You could have a 1000cc boosted engine making 500bhp that needs massive cooling ability, and a 5000cc boosted engine making 500bhp that needs virtually none.
Although pointless information wise, this is how my car was. What im trying to achieve is by down sizing the intercooler size and going to a more efficient core, I should then be able to have more of a bumper and make my car look alot more subtle, but still improve performace.
![](http://i9.photobucket.com/albums/a97/boy_racer2f2f/Corsa%20LET/IMG_0263.jpg)
Im sure you will agree, it looks ghastly above!
As Corsas do ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
You really need to be giving the core supplier a lot more information. Engine size, power, boost pressure, turbocharger etc etc.
Even better if you can add current temperatures before the IC and after, and again boost pressure before and after at present
There is no generic sooper dooper 500bhp core that works for all 500bhp engines.
But equally as important as core design, is end tank design. The generic egay stuff like you have generally work ok because they are big. But their end tanks are crap. They need to be big and free flowing, and designed so air can pass evenly through the entire core. That can make a good difference to efficiency. No sense having a great core but having crap airflow through it.
Steve im actually in mid conversation with CR turbos about all above that you just wrote as I want to run one of the new GTX28 range of turbo's. Power wise 400 would be nice but as said 380 is more then enough as I want a quick spool and broad powerband on my 2.0 engine for what will be mainly track and fast road use. I have no interest in drag or topspeed at all.
