aspirated cosworth
aspirated cosworth
can anyone tell me? to run a sierra cosworth head aspirated do i need to change the standard turbo cams or headgaskets thickness want to fit head on forged rs2000 pinto bottom end.
Deffinetly the cams will have to be changed to correct N/A versions for your engine and dont forget you will have to have pistons pocketed to suit valve size and lift but a standard head gaskett should be fine although I would probably use a small turbo escos gaskett
Adam Graham
06-09-2015 06:04 AM
