Sierra diff change
Old Nov 21, 2011 | 01:25 PM
busa bob's Avatar
busa bob
Default Sierra diff change
Will scorpio Rear diff fit to sierra beam? is diff casing that diff mount bolts to different? interchangeable? Its for my estate
Rob
Old Nov 21, 2011 | 01:53 PM
Marc sierra's Avatar
Marc sierra
I assume that with Scorpio you mean the bug-eye model (as the Granada mk3 was also called Scorpio in the rest of Europe)? The bug-eye Scorpio uses a 7.5" diff, but the rear cover was changed somewhere half way production. The old cover can be fitted to the new diff though. There are also two versions of the flanges for the driveshafts. The 2wd Cosworth uses 108 mm flanges, while all other Sierra and Granada mk3 use 100mm flanges. I think (but I'm not sure) that the bug-eye also uses the 108 mm flanges, like the 2wd Cosworth. But be aware that there is no bug-eye Scorpio that uses an LSD...
Old Nov 21, 2011 | 10:21 PM
busa bob's Avatar
busa bob
I know its not limited slip mate just noticed mount on diff case was different, I've got 1.8cvh estate and diff as gone but been offered sorpio diff from as you say ultima ( bug eye) scorpio cheap as chips and i have couple pairs of spare 108mm shafts as well to make it up plus i can put discs on rear ready for when i 24v it ..
Thanks Marc for your help and info greatly appreciated
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
robbo9006
11
Sep 1, 2015 02:10 PM
andyrs1600i
Aug 30, 2015 07:21 PM
cameron2
Aug 25, 2015 07:18 AM
