cossie swap thread
cossie swap thread
no not a for sale or parts trading thread
the aim of this thread is to educate those of us relatively new to cossies what can swap between the cars either between the cossies or thier respective base models.
Some of you might think this is noddy stuff, but not everyone has decades of cossie experience so it would be beneficial to write down some of the basics for newbies/recent cossie owners. Also useful for knowing what goes between what for conversions etc.
these are my questions so far....
Engine
other than obvious differences like 200/205 block, what is interchangable between the YB lot??
heads?
cams?
pumps?
camshaft drive/auxialliary drive?
ancilliarys - alternators, PAS, dizzy, aircon etc etc
manifolds?
turbos?
pipework??
cooling system?
oil system?
Transmission
Diffs: I know there are different sizes between 2wd/4wd but what can be fitted to what? ie can a 7.5" diff fit a 4x4 beam with standard prop etc etc
also are some non cossie diff parts compatable?
driveshafts, CV's etc. what bolts up to what?? which is stronger etc?
gearboxes. Whats needed to swap between 4wd/2wd etc.
Suspension
dampers/springs
rear beams/subframes - scorpio cossie, 4wd, 2wd, etc
anti-roll bars
TCAs
hub carriers.
Brakes
what can swap between what and what changes needed to fit different models.
Steering
Racks
PAS
linkages
columns etc.
just the obvious ones so far, then things like which jag diffs fit, what other ford parts can be used etc.
Engine
heads?
cams?
pumps?
manifolds?
turbos?
pipework??
cooling system?
oil system?
Transmission
Suspension
dampers/springs
anti-roll bars
TCAs
hub carriers.
Brakes
Steering
Racks
PAS
linkages
columns etc.
I have answered each section below, I own a 2WD model, never had 4x4 so just using eductated knowledge, hence "Think" being used alot.
Now I can give my fingers a rest and eat some cake and watch Crimewatch!
Martin
Martin
Engine
Thats kind of answered in individual sections which you have listed below, as they are basically the same engine in respect to internals.
heads?
Think the heads are interchangable, 4x4 was revised and has better water jackets etc.
cams?
Think they are different, and you need a spacer if wanting to fit one to the other, IIRC it's 4x4 to 2WD.
pumps?
99% they are the same, sure Pinto is as well!
The alternator on some 4x4 models was moved to the nearside and the PAS to the offside (Maybe for Air con models?) in any case the alternators are the same that being a 90A Bosch item. Dizzy is the same I think, aircon was only a 4x4 option (In the UK at least)
manifolds?
Sure they can be interchanged, 2WD is better if aiming for higher power.
turbos?
pipework??
cooling system?
4x4 cooling system is far better than 2WD, stat housings are different, as are expansion tanks. 2WD NLA and command crazy money second hand, 4x4 still avaliable from Ford for circa a reasonable £35
oil system?
Transmission
As mentioned below
If you can find a lesser model with a 7" LSD then yes.
2WD shafts are bolted with T50 torx screws to the diff and hub, 4x4 are splined like lesser models (I think)
Suspension
dampers/springs
4x4 springs are different (4x4 has higher ride height), dampers are also different (4x4 front struts are thinner or thicker can never remember which way round it is, thus are NOT interchangable) All 2WD Cosworth is interchangable, although being petty the Saph does have slightly different damping rates to the 3DR.
2WD has a unique beam and so is the diff (7.5") lesser models and Cosworth 4x4 are 7", they are interchangable however, both are LSD'S. I believe the Granada/Scorpio Cosworth to have the same diff, and possibly the beam as well?
Some even sand the diff casing down or cut and reweld one of the lugs where the diff mounts to the beam, in order to fit the larger diff.
anti-roll bars
Escos rear is 24MM, and is the widest one, the 3DR or 2WD is 16mm, in any case I imagine they are all interchangable being they all are the same cars mechanically?
On another note 3DR trailing arms have a different roll bar mounting point to other models.
TCAs
Saphs are the same in fact I think all models may be the same, 3DRS are different.
hub carriers.
Brakes
3DR/Saph, of course have the same hardware, that being 4 pot fixed calipers up front and 283MM VENTED discs and single sliding calipers at the back with 278MM SOLID discs.
4x4 has vented discs all round and the discs are different sizes (278MM at front, and 273MM rear), and I think single sliding calipers all round, so worse than the 2WD models! I don't believe you can fit the 4 pots onto a 4WD as the offsets are massively different! Alot go down the FRS route, but you need brackets making up etc!
You can uprate a 2WD rears to that of the 4x4 but you will need the calipers as well, due to the discs being wider!
Steering
Racks
At a guess I think the racks may be the same, 2.4 turns lock to lock for 2WD anyway.
PAS
Believe the hoses and possibly reservoir are different but pumps to be the same?
linkages
Same I would imagine?
columns etc.
Engine
heads?
cams?
pumps?
manifolds?
turbos?
pipework??
cooling system?
oil system?
Transmission
As mentioned below
Suspension
dampers/springs
anti-roll bars
TCAs
hub carriers.
Brakes
Steering
Racks
PAS
linkages
columns etc.
here some parts off a escort xr3i 1.8 zeetec that fit the 2wd cossie. starter motor are the same and i have put the alternator off one on my 2wd aswell.
4x4 front diff is common with some of the XR4x4. Don't remember which engine, but as long as the ratio is right it will be fine.
EsCos rad hose is same as something like a 1.1 fiesta
EsCos fuse box - same as other escorts as long as they have the same things like int. wipers etc.
Distributor cap you can get from some other make. Can't remember what though
Spark plugs - up to quite big power use the standard escort RS turbo ones - 071C
Received 1,044 Likes
I dont know about 2wd cossies but the rear suspension arms have bearings instead of bushes in them
3dr cossie front suspension arms are different to 2wd saffs and 4x4.
Front and rear calipers on 4x4 saffs are different to the 2wd n 3dr cossie.
Im sure the anti roll bars are thicker too.
Front shockers are fatter than 2wd saffs.
Saff 4x4s had different dash to the other cossies. 4x4s have a small glove box storeage bit on the drivers side.The center consoles are different too.
4x4 saffs have bigger intercoolers than 2wd cossies.
All of which I mentioned above, bar the trailing arm bushes, yes Cosworth have bearings, lesser models are rubber
That as well as facelift models and so 4x4 also have adjustable steering, this type is known as the "Hooded" dash.
Correct, 25% larger.
Rear arbs from the Sierra mk2, Escort Cosworth, Granada mk3 and Scorpio are all the same fitment but different diameters:
Sierra XR4x4 - 14 mm
Cosworth 2wd - 16 mm
Cosworth 4x4 - 18 mm
Escort Cosworth - 22 mm
Granada Mk3 24v - 18 mm
Scorpio - 20 mm
Scorpio 24v - 21mm
Front calipers are the same for: Cosworth 4x4, Escort Cosworth, Granada 24v, Scorpio 24v and Mondeo V6
Rear calipers (solid discs) are the same for: Cosworth 2wd, any Sierra (non-Cosworth) with rear discs, Granada mk3 (not estate or 24v)
Rear calipers (vented discs) are the same for: Cosworth 4x4, Escort Cosworth, Granada 24v, Granada estate, Scorpio 24v, Scorpio estate
There are 2 versions of the rear subframe, one for the 7" diff, the other for the 7.5" diff. Most regular Sierra's had the 7", all Granada mk3's (except the 4x4) had the 7.5".
Rear diffs
7" version - The Cosworth 4x4 and Escort Cosworth have the 7" diff with 3.62:1 ratio and LSD. The same diff is fitted to the 2.8 and 2.9 XR4x4 and the Granada mk 4x4.
7.5" version - The Cosworth 2wd has a 7.5" diff with 3.64:1 ratio and LSD with 108 mm drive flanges. The Granada 24v uses the same diff, but has 100 mm drive flanges (like all other Sierra/Granada diffs). 108 mm drive flanges can be swapped over
The fitment for prop shafts and driveshafts is the same for all diffs (except the Cosworth 2wd with the 108 mm flanges)
Rear suspension arms
All rear suspension arms for the Sapphire Cosworth (2wd and 4x4) and Escort Cosworth are the same. They use uniball joints to the rear subframe, unlike the rubber items for all other Sierra's. Granada 24v also has the uniball joints, but has different suspension arms (wider and more negative camber, but do fit with the correct driveshafts)
Rear shocks
All the same fitment for Sierra Cosworth/Sierra 4x4 and Escort Cosworth (Koni's are even same part number)
Front shocks
Cosworth 4x4, Sierra 4x4 is the same fitment (Koni's are even same part number)
Scorpio - 20 mm
Scorpio 24v - 21mm
Rear diffs
Rear shocks
Front shocks
grishenko45
09-09-2015 12:58 PM
Thanasis
07-09-2015 07:33 PM
