Wiring Apexi AVCR into Omex 600 loom
Does the Apexi not want the following:
Power, Ground, Throttle, Speed, and RPM which would need to come from my Omex
Or do you mean because the Omex can control a wastegate already? If so i want adjustable boost per gear and the ability to change settings at a touch of a button
Wiring Diagram for the AVCR
Pin Details and wire colours to help workout what to splice into for the OMEX.
Iv got both of the above of mine and had the AVCR working fine, but I never got the chance to get it mapped with the raised boost pressure so set it to bypass mode so the wastegate opened on spring presure only.
Hope above helps.
Hope above helps.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
muz
Sep 30, 2015 08:29 AM
