mahle pistons with 10:1 compression
Im looking at a set of cosworrth mahle pistons that are running about 10:1 compression with big valve cut outs . but wot i need to no is 10:1 compression ok for about 380 BHP on a T34 the cut outs are a must as i will be running a BD14 inlet cam
10:1 does seem pretty high, what ecu you using?
here is the link to were they are i did not wont to put it up but i need to no
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=p5197.c0.m619
I was thinking about these as the block im going to use in my FOCOS needs a rebore so i will need new pistons which cost about £450 then i will need cut out putting in as i will be running a BD14 inlet cam which cost about £100 so all in £550 as to £350
1 Post
I was like that too, but ended up buying new Mahle's around the corner from Harvey's place and had him do the necessary machining. Its piece of mind also ain't it, that the rights bits are in the heart of your engine
Not that far from Birmigham, so will take a drive down when yours is near completion
I'm no expert, but they look standard with cut outs??
For that price i'd suggest getting brand new ones any way as they are arond £50-£60 more?
1 Post
A Focus Cossie is o.k. at 350bhp, but more usable at 380bhp onwards, especially if its going to be 4x4 that's not as lively as a RWD.
deathrider666
28-09-2015 06:12 PM
