advice needed
Old Oct 2, 2011 | 08:30 PM
clyde 1800's Avatar
clyde 1800
Default advice needed
is it possible to put a turbo onto a standard injected pinto engine?
or do you have to lower the compression?
Old Oct 2, 2011 | 09:35 PM
djmillsy's Avatar
djmillsy
Fife Radge
anythings possible but would you want to?
Old Oct 2, 2011 | 10:07 PM
clyde 1800's Avatar
clyde 1800
i already have the engine built and all the components for it the only query i have is should i put in cosworth pistons and conrods? this will lower my compression
Old Oct 2, 2011 | 11:30 PM
Less.'s Avatar
Less.
having a mid life crisis
think its been done a few times maybe look on turbosport.see if it has been done on there or someone will probaly know someone that has
Old Oct 4, 2011 | 07:04 PM
clyde 1800's Avatar
clyde 1800
thanks for your help lads go and take a look at my restoration thread
Old Oct 4, 2011 | 07:39 PM
martysmartie's Avatar
martysmartie
Been done plenty of times, Turbo technics even done a conversion, before the EFI varient of the Pinto! You would need different management, as the standard ECU will be very basic and won't be able to manage or have any conception of boost!
The Cosworth interals are stronger but it may effect other things if it will change the C/R.
Martin
Old Oct 5, 2011 | 12:13 PM
wilky's Avatar
wilky
i did mate ,it on a 1600 though run it on megasquirt mad 107 bhp at 5-6 psi i had it running at 12psi for a year but broke the box so i,ve put a cossy box in there [which don't fit
the starter and clutch ,change fly wheel which don't fit as the crank on a cossy has 9 bolts
so got a cosy bottom end going in there now]
but yer can be done mate and goes good
Old Oct 5, 2011 | 02:01 PM
R4N SS's Avatar
R4N SS
you run it as is on low boost, ecu change will be better as you can map it properly.
if you want more boost then you would need to lower the CR
Michael Wisbey
Aug 14, 2015 11:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
