st200 air box or sealed induction kit
hi
when i bought my st it had an sealed induction kit with no air feed, so i bought a feed and fitted im debating wheather its getting enough air or not and was wondering what other st driver think. i am considering buying an air box with a k and n or similar any ideas as i never driven one with an air box
cheers
cheers
Spelling Club King!
We tested an open foam cone, a sealed (Pipercross Viper) filter and a foam panel filter in the standard airbox on an ST200 - We tested the inlet temps at idle, 50mph, 80mph, and under acceleration between 20-80mph.
The standard airbox gave a 113% increase when compared to ambient V full throttle inlet temps, the open filer gave a 138% rise, and the shielded cone just 22%!
Pretty conclusive. Just make sure that there is a good, unrestricted supply of fresh cold air from the front of the vehicle to the filter.
ok dan cool cheers for that,I do have a big cold air feed mounted behind the bumper buy the air con compressor which goes straight to the filter.
was it a k&n induction kit u tried I heard they can produce heat soak (mousing) when hot, so the viper never came up good did that have a good air feed to it
Spelling Club King!
Moosing's nothing to do with heat soak - it's the noise the standard induction set up can produce. It can be cured by an induction kit, not caused by it.
All the filters were Pipercross to give some 'standardisation' to the test. The results would be very similar no matter what brand was used, and K&N aren't any more, or less likely to suffer from heat soak than any other brands.
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
track.focus'd
12-08-2015 05:53 PM
blakey100
04-08-2015 08:17 PM
