Focus TDCI injector testing?
Old Sep 25, 2011 | 05:23 PM
CraigJ's Avatar
CraigJ
Default Focus TDCI injector testing?
Right i may have narrowed my starting problem down to a bad injector.
I read online about pulling off the leak of pipes and unplugging the electrics then cranking the engine.
I have just tried this and i am getting very little fuel from 2,3 and 4 it is just a little trickle but no 1 is squirting about an inch. I'm guessing this is fucked?
Could this be causing the car to struggle to start?
the only fault code i can get is p0251 (Injection pump fuel metering control a)
I know these injectors have to be coded to the ecu but i was wondering if i got another injector will the car run? I just want to test if it starts first time. Or does it need to be coded to run?
Any help/advice would be great.
Old Sep 25, 2011 | 06:14 PM
cossiegreg1's Avatar
cossiegreg1
Alright mate, the best option is whip all 4 injectors out, (make sure you number them) and get them tested. hopefully your pump is ok. if its just a dodgy injector the tester should be able to repair it, if not he should be able to supply a recon. dont worry about codes, i had 3 original injectors and 1 exchange,and after a few mile the ecu learned it.
Also the tester will check for swarf and fingers crossed your pump is ok. what milage is the car on?
just look for a delphi specialist in your area.
Old Sep 25, 2011 | 06:19 PM
CraigJ's Avatar
CraigJ
the mileage is 105k
cossiegreg1
try these.
WAKEFIELD DIESEL CENTRE
Be the first to add a review WAKEFIELD DIESEL CENTRE
5, Pollard St, Wakefield , WF3 3HG 2.3 miles N
Tel: 01924 668497
Old Sep 25, 2011 | 06:22 PM
cossiegreg1
is it pre 05? tdci ford are notorious for pump & injectors around the 100k mark.
the pump usually breaks down and puts swarf in injectors, and the whole lot needs changing. i spent Ł1500 hundred on repairing mine.
Old Sep 25, 2011 | 07:08 PM
CraigJ's Avatar
CraigJ
Its a 2004 1.8 tdci
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
