2wd rack ?
C**t
2wd rack ?
Is a Cossie rack actually any different from a normal Sierra ?
I have just a regular one on my car and it's about 2.5 turns lock to lock.
Is the Cossie less turns than this ?
C**t
The only difference is the Cossie one has restrictors fixed in the end of the rack to stop the wider wheels catching the suspension.
This gives less turns lock to lock, but it actually just makes the turning circle bigger.
If you need a replacement cossie rack buy a standard one and refit the restrictors.
C**t
Good to know there is no difference worth wanting one. Sounds like they would be worse then with less lock !
C**t
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
