GT3071-3076 Laggy?
GT3071-3076 Laggy?
Just a quick one for those who have a GT3071 or GT3076.. Do you find them laggy or are they a nice turbo to use on the road?
Im going down the GTX route but undecided on the 3071 or 3076.. I think the 3076 may be slightly laggy for the road?
one of Harveys engines he's got 1.9bar / 28 psi at 3200RPM with a GT3076 so would probably start coming on boost at 2500ish rpm
what power you pushing out Neil?
Im using a GTX3076 on mine, starts spooling at about 2000rpm and is about a bar at around 3krpm!
i wouldnt say they are a laggy turbo at all and i would defo recomemend them. The power delivery is amazing!
My comp ratio is around 8.5:1 and i have quite a heavily ported head aswell and it still isnt laggy!
I use a 3076 with a .82 ex on the road, 450 bhpish running 30 psi, and its certainly less laggy then my old t34.63. I use to run a .63 on the gt30 but I found a .82 going for cheap so I grabbed it. Go for one mate, you won't regret it.
I'm definatly going for one just need to know if the 3076 is laggy s thats got the potential to get me the power I'm after and going by harveys dyno sheets it seems to come in strng at 3200rpm all the way to the limiter.
what exhaust housing you got mate?
I know i was thinking 3071 to keep the lag down and because the GTX has a larger compressor wheel it could push through more air thus getting the power of the GT3076.. but from the graphs your dad set me a normal Gt3076 hits 2 bar by 3200rpm which looks like it will make a extremely quick car plus the fact it should produce around 400lbs/ft at 3000rpm is even better
judging by the GT3076 and T4 graphs I have the T4 dosent come in hard until 4000rpm where the GT3076 does at 3200rpm but then T4 has better top end power and torque.. but I'm assuming the GTX3076 will be just as good toped as the T4 but with an earlier spool up.
On a previous thread somewhere, I seem to remember chip saying that a gtx3071 will make the same power as GT3076 but with the spool of a GT3071, The GTX3076 will make the same power as a GT35 but spool like a GT3076. Thats the way to view how the GTX series turbo works.
Hmmm wont the 3071 be at its limits at 530hp if it does actully make that power.
May be better to gofor the 3076 and have it having a easy time producing 530hp
I personly would be going GTX3071 and having one hell of a driveable engine with a great spread of power although slightly less at its peak.
B1mbo
Tim, your going off hearsay, not fact, they expect them to flow that much. The fact is though, the exhaust side is the issue, not the compressor, so by making the comp side bigger in Essenese your not gaining anything where you need it.
I'd be interested to see what oower they would make at a acceptable back pressure
In terms of lag on the road its not even worth measuring the differance between a 71 and a 76(both on .8x) as it'll be minimal.
In terms of threshold.... or more important when does it get on full tilt imo realisticly you'll be looking toward 3.8-4k for the 71 and around 4-4.2k for the 76 but it will be dependant on spec/setup also(again both .8x)
Theres always the choice to come down to .6x but if you going to be holding in WOT for a decent length of time(vamx etc) or running toward the fun side of the rev range more often(track days) you'll not realy want the restriction of the smaller housing. This may also restrict.... ultimate performance of the comp. side. For a road car its well worth considering though.
i have had a t4 on my 3dr love it my mate got a saff with gt30 we both didnt like it he swap it for a t4 and the car was better...i think the gt range turbo's sound good on a paper but dont think they work as well.. maybe try a T4??
cossie fan (unluckerly)
tell him to take it to someone who knows how to set up/build a car then lol mine dosent really have any lag with my m.a.d 500 conversion with a gt30
if anyone got a laggy turbo then take it to gsmotosport 07940 181847 for a set up if your not happy dont pay him!!!
My old 3dr comes in @ 2200 rpm with T4...driving along in 5fh gear @ 40mph and @ 2000rpm coming up to a round about i would not have to change down, it would pull like a train.. long time ago ronnie with the black 3dr had a gt30 change it for t34 and he love it.. my old 3dr is whitey car runs a t4 with no lag.. i can say this for sure big turbo's are not laggy, most of the times its down to the engine spec and mapping....same with the T34 its got to have the right housing and spec and mapping...
