Bleeding hydro handbrake
Old Aug 31, 2011 | 08:45 PM
wide ka's Avatar
wide ka
Default Bleeding hydro handbrake
How do people do it?
I've one in my kit car, carnt get the air out of it! It's on twin cylinders so rear has it's own master that then Leeds to the handbrake then out to the rear brakes
Old Sep 1, 2011 | 09:14 AM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Have you definitely got it plumbed in right?
Normally on hydraulic handbrakes you plumb the master cylinder for the handbrake in backwards. You connect your rear circuit master cylinder 'out' from the pedal box to the handbrake master cylinder 'out'. The handbrake master cylinder 'in' then goes to the rear brakes.
This allows the fluid to flow through the handbrake for normal brake operation, but will still pressurise the rear brakes when the handbrake is operated.
I've never had to do anything but bleed as normal on the rear brakes.
Old Sep 1, 2011 | 09:21 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
We dont plumb them in like that Will, maybe I've read it wrong? We go from brake master cylinder to the 'in' (or what you'd normally plumb the reservoir to) and the outlet goes to the rear brakes.
But to answer the guys question, to bleed the handbrake you simply bleed the rear brakes, you could loosen the outlet pipe on the hyd h/brake and pump it that way and then blled the rear brakes if you're getting into difficulty.
Old Sep 1, 2011 | 08:16 PM
wide ka's Avatar
wide ka
I've tried it both ways with the hoses and cannot get the air out of the system, a little strange I think, I'll keep trying though
Old Sep 1, 2011 | 09:35 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
mine was as per how martin said.
the fluid in goes to the rear of the cylinder, and the out goes to the rear brakes.
i just bled as normal and it was fine. maybe your cylinder is fooked?
i did use a vac bleeder on a compresor tho, best tool i have bought to work on cars with!
my wand was fooking brutal lol
Old Sep 1, 2011 | 09:53 PM
wide ka's Avatar
wide ka
Hmm, maybe it's all new though, unsure how the cylinders fail? Worked fine last year
Old Sep 1, 2011 | 10:19 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
well, if the seals go it wil have air in it.
just keep trying to bleed it mate, see how you get on
Chas
Oct 5, 2015 07:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
