Puma 1.7 engine help
Old Aug 24, 2011 | 07:07 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Default Puma 1.7 engine help
Anyone know about puma engines?
What length are the conrods centre to centre?
Old Aug 24, 2011 | 10:11 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
not sure off top my head. Not listed on ETIS or the rally motorsport engine info either.
Im sure shawspeed or swindon race engines will know as they build race Zetec SE's and swindon used to build the kit car rally engines as well as the zetec SE's used in formula fords.
Old Aug 24, 2011 | 10:29 PM
Chip's Avatar
Chip
Yes they probably do know, lol
I just wondered how it compared to the 137mm for the 1.6 engine which gives a 1.68 rod ratio with the 81.4mm crank
I know the extra capacity comes from the piston size going up from 79-80 and the crank from 81.4 to 83.5.
But I was wondering if they used the same rod and just moved the piston pin higher, or if they kept the piston pin at the same height and shortened the rod by 1.05mm
Old Aug 24, 2011 | 10:44 PM
Psycho Warren
Carbon Crazy
wouldnt know without stripping one apart
maybe try on pumapeople and look for member "turby" as he built a turbo one from scratch including new rods and pistons so i suspect he'd know exactly how it was done.
Old Aug 24, 2011 | 10:49 PM
Chip's Avatar
Chip
Most people who buy rods dont know the length of them!
Old Aug 24, 2011 | 10:54 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Might be worth a post over on zsoc.com. Either that or get on the phone to Jon at Shawspeed.
Old Aug 24, 2011 | 10:58 PM
Chip's Avatar
Chip
Am amazed there dont seem to be any technical details of these engines published online, its trivial finding this info out for other engines.
Dont really want to phone up companies to waste their time when im not buying anything from them.
Old Aug 25, 2011 | 08:47 AM
Psycho Warren
Carbon Crazy
chip, ford probably never openly published the data like for other engines. It was originally designed as a throw away engine hence you still cannot buy rebuild parts for the bottom ends from ford, you have to go via other places who did race engines or similar and had the data.
Old Aug 25, 2011 | 08:56 AM
Chip's Avatar
Chip
Fair enough, I'll get Tank Mike to measure one next time he has one in bits, he's normally got them lieing around anyway as he does so many puma engine conversions on fiestas and the like
Alloy wheels and ICE for sale
14
Sep 26, 2015 05:40 AM
Ben26
Sep 1, 2015 06:29 AM
Ben26
Aug 27, 2015 08:56 PM
Ben26
Aug 11, 2015 04:19 PM
Aug 10, 2015 12:08 PM
