how do u loosen the fan belt tensioner on mk3 mondeo??
as title i just put a new alternator on, but need to looesn the tensioner so the belt will go round, but not sure how to loosen it.
any help appreciated
thanks
thanks
sure some of these have a wind on stretchy belt and no tensioner, u will need special tool in that case it comes with the belt when u buy it from ford
maybe ,they said the same thing about the v6 type all that was needed was a 1/4 t bar put in the "special tool" square hole and just pull!
that sounds just like the v6 type ,the hole is low down on the arm had to go in from the wheel arch on mine to get the right leverage
Resident Wrestling Legend
http://www.fordwiki.co.uk/index.php/...er_replacement
this may help
and this is the tool you need
http://www.toolbox.co.uk/sealey-vs48...ign=GoogleBase
this may help
Testing the future
the fan is electric, not driven by a belt. hope that helps
on a more useful note, tensioners these days seem stiff as they are hydraulically damped so you cannot just wang them open with brute force. a constant, steady force will open them easily
Adam Graham
06-09-2015 06:04 AM
