General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I've got focus rs discs and calipers under 16s comp fr had to shave a bit off the caliper but the biggest problem is the clerance between the caliper and the rear face of the wheel as the discs don't have much of a offset
Let me know how you get on mate as i would like to do this. Failing that you can use Porsche/Seat Leon radial mounted calipers, which give you a little extra clearance.
I'm on 330mm 4 pots behind 16's, not comps though and unsure of the actual offset
interesting to know how you did it. I want to do it so i can get some 16" gravel/snow tyres for winter fun. Dont want to have to change brakes to swap them over. Dont mind spacers though.
Custom bells and brackets, the calipers are not your normal AP 4 pot though, their fooking massive, 36mm discs
I would assume the 2 piece bells are because the car originally ran different uprights, that or they had 4 bells and machined one into the other as they are rather thick.
