AFR readings
B1mbo
Too weak on cruise and slightly rich on tick over, problem with tockover is cosies don't like much weaker than that so not far off
11.3 is too rich but when it climbs to 12 that's spot on
But what gauge are you using?nas most the aftermarkets we have done back to back with our kit can be reasonably close to way off!
aem are good, the supra runs 10.9 - 11 afr on tdis ŁŁŁŁ gear, my aem shows 11.2 so within 0.2 and Ł130 cant be bad imo.
both my old skyline and supra cruise in the high 15s to low 16s and have both been capable of almost 30mpg which is good imo for big sixes.
my aem was stuffed in the back box when i first got the car and quite a few on here said that wont work as it was in a massive pipe, but it did work and the aem showed leaning off big style, which it did on the dyno just the same with ŁŁŁŁ worth of wideband equipment.
was you aem not in when the car was being mapped, or straight after mapping ? have the afrs changed since mapping most importantly ?
Turbocharging Technician
B1mbo
James, were they 500bhp with lairy cams? You just said any yb will cruise at 14.7, I dissagree
I've been mapping the above today and it will not have it, you can hear it just dosnt like it at all and can tell it's so much nicer with a touch more fuel in
But even calmer spec, 440 t38 lump still could only give it 13.8s ish before it didn't want to have it.
I'll map by the way it sounds, you can tell when a yb is happy, as you will know, its in the 13s, you can tell the instant you take it from high 13s to mid14s
Anyway just my opinion! Everyone has their own idea and won't change the way they map by someone on the net lol!
jimbo, if your cams are that lairy then your afr on cruise will not be a true reading as there willbe a lot of unburnt fuel entering the exhaust.
Lairy cams do of course make a difference as they not only create charge dilution at low piston speeds but they also drop the intake velocity down drastically which greatly affects mixture distribution. The affect on mixture distribution often needs to be offset somewhat by an excellent quality plug with a bigger gap. I am sure you have all noticed a quality Iridium plug with run a CVH and a YB better at 15:1 that some iron girder like 071 or C57 plug that make them sound like they are hunting at idle and cruise? You wouldn't be mapping too rich to save fitting good spark plugs and ignition systems obviously... LOL
The interesting thing I note from all the mappers on this topic talking about the engine likes this AFR, and it dislikes that AFR, etc, is that nobody has mentioned they adjust the fuelling tables and then the spark lead tables?
You guys do know the combustion initiation and burn speed at 13:1 is different to 14.x and 15.x:1 don't you? You cant just dial fuel in and say.. "Ah, thats better" what you probably did, was correct an incorrect advance map by changing the burn speed to something more suited to your spark map so of course it sounds better.
I am sure the missing spark advance discussion was just an oversight of course...
I will be attacking IB E-Mails as of 12pm today so if you replied last night / today it will soon be all sorted, I will do yours first pal.
John
