had the vr6 on VAG COM finally! and also emmisions are bad!
Old 23-07-2011 | 11:21 AM
paceo's Avatar
paceo
Angry had the vr6 on VAG COM finally! and also emmisions are bad!
hi peeps me again, got a very good friend who works for VW and he was in today on overtime. we put the car on VAG COM and found these fault codes -
00527 intake manifold sensor - it was broken off :-(
00533 Idle Speed Regulation - yes it idles bad and cuts out sometimes (tried several idle valves and does it) :-(
also we put a probe up the exhaust and the high idle (2500rpm) emmisions are very high and the low idle emmisions are high.
so if anyone could help that would be fantastic
Old 23-07-2011 | 12:42 PM
spunk122's Avatar
spunk122
Try cleaning out the throttle body with carb cleaner, delete fault codes, reset the basic settings and run an adaptation with the vag com.
Then see where you are from there....
07-10-2015 01:56 PM
mondeomark
28-09-2015 07:28 AM
