FAO Stu --> Chip ID
PassionFords Creator
Hi,
Sorry, just seen this! The info we hold on file for that item are as follows:
Basic Calibration Specification for 4189:
Originally Sold: - June 2008
ECU Type: - L8 ECU
Babyboard Required: - Yes
Pectel or Weber: - Weber.
Encryption Key required: - Yes - Green
Engine Type: - Ford YB 2.0
Engine Compression: - Standard
Head Spec: - Standard
Camshaft Spec: - Standard:
Injectors: - Siemens 55lbph Low Impedance
Turbocharger: - T34.63
Map Sensor: - 3 bar
Intercooler: - RS500 type
Additional Features Installed:
Closed Loop active: - No
Air Injectors active: - No.
Serial Data active: - Yes.
Anti Lag active: - Yes
Launch Control active: - Yes
Flat Shift active: - No
ECU Type: - L8 ECU
Map Sensor: - 3 bar
