max cpu temp
Old Feb 12, 2005 | 01:00 PM
AlexF's Avatar
AlexF
Default max cpu temp
on a P4 3.2 with HT
whats the max temp before I need a new pc?
Alex
RANJ's Avatar
RANJ
your mobo should switch ur pc off if it gets to hot before any damage
Old Feb 12, 2005 | 01:01 PM
AlexF's Avatar
AlexF
its a asus so will it?
is 75 degree c too hot?
alex
Old Feb 12, 2005 | 01:03 PM
RANJ's Avatar
RANJ
has the pc slowed down at all
asus is one of the best money can buy, i wdnt build pc without as asus mobo
it should have high cpu temp cutoff
Old Feb 12, 2005 | 01:45 PM
Phil's Avatar
Phil
Jeebus
It all depends if the CPU Temp power-off feature is enabled in the bios.. 75 is far too hot, you want it to be around 40 degrees when idle - try leaning the dust out of the fans
Old Feb 12, 2005 | 03:20 PM
AlexF's Avatar
AlexF
lol its not at idle...
its at full chat with every cycle mopped up!
Old Feb 12, 2005 | 03:24 PM
SimonT's Avatar
SimonT
I got my AMDXP2800 overclocked to f**k!!
Its running at 73 degrees C!
Just a matter of time now....
Old Feb 12, 2005 | 03:30 PM
Tim_H's Avatar
Tim_H
Alex,
I've a couple of Cosworth fans that i'll let you have cheap.
Old Feb 12, 2005 | 08:16 PM
AlexF's Avatar
AlexF
well its run all day and stablised at 75 degrees C
the fan was on and off at 1st but now its sitting at the same speed
strang things computers!
alex
Old Feb 12, 2005 | 10:07 PM
caprixpack's Avatar
caprixpack
lol my amd athalon thunderbird used to run at around 95 degrees c coz id clocked it by 200 MHz and not uprated the heat sink and fan, after the wiring melted on the fan i upgraded to the beast its got on now has a 72mm directional fan and the heat sink is huge runs at around 40 degrees c now
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
Ben26
Sep 3, 2015 07:55 PM
