Norwegian Focus Cossie/Jap (WRC look now)
#43
Welsh And Proud
Hmm will have a loo into that.then I would only need to worry about the tunnel.
How can the chassis legs be used?i thought the cross member bolts was shorter and Wong reach the legs?
Do a1 rally sport have z website?
#44
tunnel can be fabricated or you could use the sierra one.
rear cross member mountings can easily be added to the focus chassis legs using threaded inserts .
#46
Andy il pm you anything you need know mate
2wd tunnel if rwd with the section bulkhead
Only problem iv seen with using chassis legs
Anti roll bar mounts sit really low , but compression struts would
Sort that , type in focus Cosworth in search , in resto room
There couple a1 rallysport shells
#47
Welsh And Proud
