testing injectors
Old Jul 2, 2011 | 05:14 AM
lukeytheduke's Avatar
lukeytheduke
Default testing injectors
just need to clarify the method to test these. To test for constant 12v all i need to do is pull the cap of the top of injectors? The injectors themslves dont need to be touched? Many thanks luke
Old Jul 2, 2011 | 08:19 AM
Icurus's Avatar
Icurus
Normally you would probe the cap for 12v on one of its pins, with the ignition on.
Old Jul 2, 2011 | 08:38 AM
lukeytheduke
is the cap the bit that pop's of the top with the two wires connected though?cheers
Old Jul 2, 2011 | 09:01 AM
focusv8's Avatar
focusv8
Yes, test from car chassis earth to either pin, you should get 12v on one of the pins
Old Jul 2, 2011 | 09:10 AM
lukeytheduke
cheers, anyway of testing the amal valve apart from hearing it click as i got no one to turn ignition on while i listen for the click?
Old Jul 2, 2011 | 09:12 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You will hear the amle vale click with the bonnet open when you turn the ignition on
Steve
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
