help!! chip and map sensor prob
Old Jun 29, 2011 | 07:41 PM
escoskmv's Avatar
escoskmv
Default help!! chip and map sensor prob
hi all got a problem with me car, its running 2wd cosworth l6 ecu did have a stg2 ggr chip and would only run 20/22 psi then hit over boost. i got 3bar map to go on and it wouldnt run with it. was told i need a stage 3 chip to run 3bar map sensor so i brought a ahmed bayoo 330bhp chip for it and it still wont fuckin run with the 3bar map. when you stari it up it revs its self up then revs drop off and it cuts out. you can keep it running if you keep reving it but that ent right. engine spec is wrc accrilite pistons,acl race bearins, arp bolt kit,wrc ml head gasget, standerd cams, 7.2:1 comp ratio. t4 turbo, external waist gate. i want to be running 25 30 psi can any one help or give addvice on wot to do. i dont want to spend 700 on a map sesion as i cant afford that kind of brass
Old Jun 29, 2011 | 08:57 PM
Brendan's Avatar
Brendan
struggling with reality
does any one know what the output of the sensors are? and could you test yours then simulate to the ECU to test?
http://www.aa1car.com/library/map_sensors.htm
there are 2 type of for sensor that ford use analog and digital! this could be your problem!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
jay030787
Sep 25, 2015 01:38 AM
