help with focus rs alarm!!!!!!!!!!
hi my focus rs mk1 alarm has been going off randomly through the night so i had a new battery fitted about 2 weeks ago. all was fine until it went off again last night and pissed my neighbours off even more lol. it goes off and stops for about an hour then goes again.
any ideas if i can adjust the sensitivity or what could be causing it?
thanks kieran
thanks kieran
Surely there is nothing special about the alarm though, I suspect it's the same as fitted to a regular Focus? In any case check the door switches, boot and make sure nothing is obstructing sensors in the cabin. Sometimes the LED (If applicable) gives certain "Flash Codes" when disarmed on alarm systems, which you can then use to isolate to a trigger.
Martin
Martin
