General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Hi, A few weeks back Mark at M.A.D setup my car and its 100times better then it was, the car is an MSD stage 3 setup, the turbo is a t34 with a 0.63 housing and ive noticed the amount of lag it has low down. Is there a set of cams and pulleys i can buy to counter act the lag? What cam's are recommended?
In short, NO THERE ISN'T, assuming you are on std cams, BD8's, any hairier cam will make it more laggy, swap the turbine(exhaust) housing and you will lose a lot of lag by using a smalle rone like a .48, .55 for example.
