Stack dash owners
Old Jun 23, 2011 | 10:21 PM
boost mad's Avatar
boost mad
Default Stack dash owners
Where have you put your sensors for water temp and oil temp on a YB ?
Ive got my oil pressure and fuel pressure done, just need to sort these two asap !
Old Jun 23, 2011 | 10:29 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
not a yb but i had my oil temp in a sump plug adaptor, and water temp in the top rad hose but that was probably better to be fitted in the thermostat housing
Old Jun 23, 2011 | 10:47 PM
boost mad's Avatar
boost mad
Ive currently got my defi oil temp in the wing of my sump, but it never seems to get very warm.
I thought about the water one in my thermostat housing but then thought i wouldnt get a true reading until the stat opens ?
Old Jun 23, 2011 | 11:16 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
if your running a stack dash you wont be needing the standard dash water temp sensor so fit it in the same hole. You can get thread adaptors if needs be.
oil temp copy the escos set up with a takeoff so you can put the oil pressure and temp sensor in the same place where the oil switch normally goes.
Old Jun 23, 2011 | 11:22 PM
boost mad's Avatar
boost mad
The sensor for temp for the stack is massive compared to the original one so doubt it would go anywhere near the original sensor hole. With an adaptor the end of the sensor would be out of the flow of water too
Any pictures of the escort setup ?
Old Jun 24, 2011 | 12:04 AM
Psycho Warren
Carbon Crazy
Thats where it goes.
Old Jun 24, 2011 | 06:22 AM
john_p_b's Avatar
john_p_b
my stack water temp sensor was exact same size as the original one on the exhaust side so just swapped them over.
Old Jun 24, 2011 | 06:49 AM
Spiky's Avatar
Spiky
not unrealiable cossie, but my pug has the oil temp in sump (oe) and in it's thermostat housing (oe)
seems to work ok
Old Jun 24, 2011 | 08:03 AM
boost mad's Avatar
boost mad
Warren, same as the 2wd cossies then. The way you worded it made it sound like it had some fancy bollox going on lol
When i get my head back i shall have to check as visualy my sender looked much bigger
Old Jun 24, 2011 | 12:01 PM
Psycho Warren
Carbon Crazy
i thought escos were the only cars to come with oil temp and pressure guages as standard??
Old Jun 24, 2011 | 12:09 PM
boost mad's Avatar
boost mad
may bad. miss read the oil temp part. just assumed u ment the pressure switch and wrote it twice lol
will see if i can find an escos adaptor
Old Jun 24, 2011 | 12:30 PM
Psycho Warren
Carbon Crazy
just remember you need a pressure sensor that does combined pressure guage and pressure switch so that the oil light works still. for a track car you NEED a big red oil light rather than an easily ignorable oil pressure alarm on your dash.
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Fordmad!
Sep 29, 2015 07:03 PM
rsguy
44
Sep 29, 2015 03:29 PM
Mc5506
Sep 29, 2015 09:06 AM
