Repairing Alloy Rads...
Right then guys, I stupidly managed to run a drill bit into the front of my Airtec Rad (TWAT). Anyways ive managed to put a hole into part of the core. Is this repairable? Or shall I bend over and spend another £200 on a rad
Pic below
![](http://i950.photobucket.com/albums/ad343/fhtocca/136ad475.jpg)
Not the case, needing to cut off the end tanks, I've repaired a lot worse than that, with 100% success, would just need to knock out the immediate surrounding fins as said, then tig welder out, may even need to bend the other nearby slats out the way, then bend back once cooled but is perfectly repairable.
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
