Whos used a BD14 exhaust cam
Old 11-06-2011, 06:31 PM
  #41
1374lee
1374lee's Avatar
Great thread this,very helpful, I am pondering over ex cam choice right now.
Thanks.Lee.
Old 11-06-2011, 06:35 PM
  #42
Mark Shead
Mark Shead's Avatar
Thanks.Lee.
The BD14 exhaust cam only works well on a very few specced engines and on most it doesnt work that well.
Mark
Old 11-06-2011, 07:09 PM
  #43
1374lee
1374lee's Avatar
Mark
Yes Mark, you know what my bd14 was like,you said it was lazy coming on boost.I am 99% going back to a standard ex cam as you suggested,the bd14 is coming out for sure.Can only improve the car as you said before.
Thanks.Lee.
Old 11-06-2011, 07:46 PM
  #44
boost mad
boost mad's Avatar
So is there an alternative over the standard ?
Old 11-06-2011, 08:09 PM
  #45
NEIL A
NEIL A's Avatar
Sorry to jump on this thread but what effect should the change from a BD10 ex cam back to standard have ?
Old 11-06-2011, 09:03 PM
  #46
Jay,
Sponsor
Jay,'s Avatar
BD10 is well known as the lag cam put a standard one in and it change the responce for the better Neil
Old 11-06-2011, 10:46 PM
  #47
DAN400
DAN400's Avatar
but surely a bd10 cant be much bigger than standard anyway?
would it still make much a difference going back to a standard?
Old 11-06-2011, 10:48 PM
  #48
J1mbo
B1mbo
J1mbo's Avatar
Bd range dosnt go by bigger the number 'bigger' the cam!
Old 11-06-2011, 10:56 PM
  #49
Sonic Boom
Sonic Boom's Avatar
Lift goes up as the BD numbers go up but the duration doesn't:
Rich
Old 11-06-2011, 11:02 PM
  #50
J1mbo
B1mbo
J1mbo's Avatar
Rich
I know..
I was letting dan know that you shouldnt go by the numbers they're labelled as, as it dosnt always work out in order like youd think
Old 11-06-2011, 11:12 PM
  #51
DAN400
DAN400's Avatar
feck sake looks like i ve 2 cam s to buy now instead off one,
cheers jim
Old 13-06-2011, 07:28 AM
  #52
JamesH
JamesH's Avatar
No because one is not needed
Old 13-06-2011, 04:26 PM
  #53
boost mad
boost mad's Avatar
dont start James lol, im just asking for peoples views, opinions and experiences
Old 13-06-2011, 05:24 PM
  #54
JamesH
JamesH's Avatar
Describe what you want from the car Alex
Old 13-06-2011, 06:22 PM
  #55
boost mad
boost mad's Avatar
For it to work and stop fucking about would be a good start
Old 13-06-2011, 06:54 PM
  #56
Rab
Fucking superstar........
Rab's Avatar
Old 13-06-2011, 07:23 PM
  #57
1300gt
1300gt's Avatar
To much valve over lap ruins low speed trackability/torque
Long duration cams on ex can be problematic.
Old 13-06-2011, 07:33 PM
  #58
JonnyBravo
JonnyBravo's Avatar
Not knowing much on the subject of cam choices I know Aaron at HT has put them in my engine.
Its far from standard though but sadly I dont have any graphs to use as a comparison against others.
Old 13-06-2011, 10:38 PM
  #59
boost mad
boost mad's Avatar
So some are saying standard, some saying one with less duration
Well the bd15 has less duration than the 14, so would that make it a better choice ?
Old 14-06-2011, 06:49 AM
  #60
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Mines around 480bhp using a standard exhaust cam
Steve
Old 14-06-2011, 07:10 AM
  #61
Moonstone Steve.
Moonstone Steve.'s Avatar
Steve
Yeah right
Mines 490 with a standard exhaust cam.
Steve
Old 14-06-2011, 07:11 AM
  #62
J1mbo
B1mbo
J1mbo's Avatar
A 15 works well on the ex
Old 14-06-2011, 07:26 AM
  #63
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Originally Posted by Moonstone Steve
Yeah right
Steve
Well if mine ain't around 480 yours ain't around 490
Steve
Old 14-06-2011, 08:32 AM
  #64
boost mad
boost mad's Avatar
How far up would it move the power band ?
Old 14-06-2011, 12:33 PM
  #65
J1mbo
B1mbo
J1mbo's Avatar
There is no way of actually telling without putting the engine on the dyno and seeing, move the timing to get the best gains etc, not just a case of put it in and expect it 500rpm later as it will depend on the engine itself
Old 14-06-2011, 01:31 PM
  #66
James @ M Developments.
James @ M Developments.'s Avatar
i had really good results with a BD14 ex on my T4 car, took a bit of trial and error with the timing but it did work well once it was done
Old 14-09-2011, 11:25 PM
  #67
BigErn
BigErn's Avatar
Ive just found my spare standard exhaust cam and Im thinking about changing it from the BD14 Ive got in there at the moment.
Spec is..
0.5 std comp with pockets
Std rods
Std/std crank
27mm inlet ports
25mm exhaust ports
BD16 inlet cam
BD14 exhust cam
T4 turbo
What exhaust cam would work best with that spec? Its a road only car, driven like a dick 95% of the time Im in it
01-11-2015 06:53 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Quick Reply: Whos used a BD14 exhaust cam
