any fiat people on here...
Old 08-06-2011 | 09:01 AM
saph4be's Avatar
saph4be
Default any fiat people on here...
got a problem with a doblo van that i just cant get my head around
hi all i recently had the timing belt snap on my 2002 doblo 1.9 non turbo diesel and after checking the valve clearances i belive the to be no damage as the van was just idleing at the time.
however i have attemted to fit a new cam belt in order to try it and can't seem to find the correct timing marks? i have timed the engine up useing the yellow lines on the cam belt but the engine just locks up when turning it over by hand?
now i thought maybe there was some damage which was stopping the engine from turnng over so i removed the cam shaft allowing all the valves to shut and trned the engine by hand which appears to be fine and feels like there is good compresssion there.
so any ideas? if i sent the crank to what marks i belive are tdc and aet cam to the mark the camshaft lobes are pushing a valve open on number 4 cylinder which just seems wrong so any advice would be massively gratefull before i pull the head off!
Old 08-06-2011 | 09:03 AM
chaffe's Avatar
chaffe
Turbocharging Technician
head will need to come off,at least a couple of valves will be bent
Old 08-06-2011 | 02:12 PM
I thought you said fat-so I answered!!
Old 08-06-2011 | 02:47 PM
chaffe's Avatar
chaffe
fix it again tommorow
Old 12-06-2011 | 11:47 AM
saph4be's Avatar
saph4be
well i removed the head out off frustration thus morning and as i thought there is no damage at all so it was as first thought so does anyone have any info on timing this engine up?
Old 12-06-2011 | 11:57 AM
focusv8's Avatar
focusv8
Did the crank turn without the head on?
Cancel just noticed it turned with the cam out
Old 12-06-2011 | 12:01 PM
saph4be's Avatar
saph4be
yes mate even with the cam in i could get a full rotation off crank by turning camshaft abit mate it really pissing me off as i done hundreds off cam belts but just can't get my head round this?
Old 12-06-2011 | 12:05 PM
rik-rs's Avatar
rik-rs
dunno if this any help mate..only a quick google search if its right engine or not..
http://www.fiatforum.com/punto/19733...e-engines.html
Old 12-06-2011 | 12:11 PM
saph4be's Avatar
saph4be
no mate thats a petrol engine i have spent ages on google and have posted it on fiat forum as well but thANKS FOR LOOKING
Old 12-06-2011 | 12:18 PM
rik-rs's Avatar
rik-rs
ok sorry mate
Old 13-06-2011 | 06:23 PM
saph4be's Avatar
saph4be
problem solved when the tensioner let go the belt become slack and the timing jumped causing valve to piston contact and the result was the cam shaft sprocket has moved and snapped the keyway causing the timing issue all running sweet again now!
Old 14-06-2011 | 06:53 AM
chaffe's Avatar
chaffe
It didnt bend any valves? suprising! oh well least its fixed. BTW a belt runs on a pulley not a sprocket , they are for chains
mk3ste
17-10-2021 11:09 AM
Rsmat
89
12-10-2015 08:50 AM
Adam-M
Was It You?
01-10-2015 08:55 PM
rsguy
44
29-09-2015 04:29 PM
NC53
13-09-2015 04:05 PM
Quick Reply: any fiat people on here...
