whats the best pound for pound cooler cosworth?
heres the top ones ive looked at...
spec r which everyone rates.... im realy thinking about this £780
airtec 100mm (new) and only fitted to wennys and that time attack escos both 600+hp. £395
airtec 70mm cooler £280 mixed reviews
pro alloy 100mm ive heard its a bitch to fit ??? not sure how much??
radtec 60mm ??
also im thinking of the 3" outlets but would i also need a throttle bodie thats 3" outlet to match or could the hoses from roose be used, and to what affect will this have, as the airtec 100mm and pro alloy both have 3" outlets.....
whats everyones thoughts and would be good if wenny has any feed back on the airtec 100mm
ive got swedish, gt35, autronic and looking at 520+hp so which would suit the best
thanks
radtec 60mm ??
thanks
Caraholic
Any 100mm intercooler will require the cross-member to be removed and replaced with a narrower one (see my resto thread for details ).
Personally at the power level you are running I would only go for one of the top spec ones using the quality cores. If you were below 400bhp, then it would be the Airtec one no contest for VFM, but in tests the cores have been criticised for struggling to dissipate the heat (as in having poor recovery rates). This isn't an issue for a road car, but could be on a track car.
The Spec-R one uses top quality Garrett cores from the US, hence the costs, but you can't argue with the figures it produces - at the end of the day, it is whether or not your budget can be stretched to pay for the best, or whether you can compromise on performance and take the financial saving instead.....
At 170mph, my Pro-alloy 100mm one is seeing 37°C intake temps on a 18°C ambient day.....
I appreciate the thick core ones are excellent and I had planned to look to upgrade mine but I can't really justify spending out however much the Pro Alloy or Spec R ones are on a engine that is no more than 500hp.
Don't ask me what my ACT's are, not driven the car in anger yet but I'm guessing you have an idea of what to expect as you have developed your car a lot through the years.
oh yeh i need one of your beam shim kits...
im running gt35/autronic/your swedish and big spec yb looking for a easy 520+hp
so do i throw big money at the spec r or just put up with the airtec....
For you probably the pro alloy cooler that is already fitted to the car, were you seeing high inlet temps that were causing timing to be pulled.
Scrap that just seen in your forsale post that is a pace you have fitted, thought I read before that it was a 65mm Pro cooler.
the quality of the core in the original rs turbos,cosworths etc is of much better quality than the likes of pace and airtec,and thats what counts over the size
so the spec r one will no doubt be the best as excellent core,but as i say above about the ford fitted ones welding some together looks a good cheap option to me
Caraholic
cheers thats good to know i wasnt told by airtec that i would have to mod the cross member to fit the 100mm cooler, if thats the case then its either 70mm airtec and door strips or spec r and other stuff can wait...
Personally BEFORE you change anything, I would get everything sorted and set up on the car, as to achieve 520bhp out of a GT35 will mean you won't need to be pushing shit loads of boost through the engine to achieve this (as it is a 600bhp turbo), so you may find that the intercooler you already have is adequate. Rather than assuming it isn't, surely it would be cheaper to test it and confirm, you might save yourself a LOT of agro?
Caraholic
How well do you rate the BEHR RS500 intercooler against the other "copies" ?
There is a huge air scoop in the front so it won't be short of cold air but as you say proper testing will show if it works well enough or not.
Happily retired
Was watching Spec-r's development programme last week direct back to back against other coolers as Pete strives to improve his product.
Its not only about temps as most are saying, the more efficient & better flowing Spec-r cooler are making gains in Power/Torque compared to others. Like everything in life the best comes at a price.
https://passionford.com/forum/genera...ge-10-a-4.html
If you look at Steve's RR results you will see the Airtec was better on the rr than the spec R, only with the bumper removed was the spec R better and gained 1 bhp, never noticed this till i just read through it.
Steve
Steve
Designer/Fabricator
Steve
Steve
Steves bumper would not fit onto his car and was held on with cable ties, so that test was slightly un-fare.
He was also advised by Luke that his turbo was at it's limits.
You may get away with the 100mm one on a Sierra without these mods (as these cars have quite a bit more room than the Escort), but at the very least it would need slimline fans and to have different mounts made.
oh yeh i need a skim kit lol
Steve
Steve
but i think i need a better interior ect before i look at more power, as im happy with the speed but not with the cars apperence
