anyone know t16 rover engines?
Just want some advice really, I have a t16 engine from a 220 in a 400 estate and the headgasket has gone.
Now my thinking is that whilst it's apart I may as well upgrade it. I want to know what can be done and for what cost and potential gains to see how far it's worth going with it.
CheeRS,
CheeRS,
Does it have a PG1 gearbox fitted? If so, get the bearing cages upgraded as they fail.
Get a Klinger metal head gasket (if it had one, its unusual for them to fail!).
Pistons, well, you can get JE / Mahle which are expensive. If you can find a set from an 'O' Series or 'M' Series turbo engines, as the pistons are made of chocolate and running anymore than standard boost can cause them to melt.
O / M series pistons might let you run 250bhp, but then you'll need to upgrade the turbo as well as its a T25 iirc.
Personally I wouldnt bother
Boost addict
Easiest gains are from fitting a fmic, pulsar t28 turbo but your limited to around 12psi on standard bottom end.
If funds allow go for a set of forged pistons and rods,headwork,fast road cam, t28 and fmic. Gt it set at around 18-20psi and it will fly
oh and if you can stretch.to it a tubular manifold from aa autosport.
Cheers for the advice, I've heard the ecu's aren't the best when it comes to tuning? Seems like you have to go straight for the big internal mods when looking for any decent power gain then. It's tough to decide wether it's worth the effort but the car is an awesome sleeper already. I suppose if I built a proper engine for it I could always break it to regain some money if needs be...
Boost Junkie
id go for bigger turbo, mls headgasket, ms managment and a front mount cooler for a good reliable 280bhp, the early t series bottom ends (before 95) had forged pistons, you can tell an early engine by the inlet manifold saying TURBO where late choclate engines have just INJECTION
Vacuman
16
03-09-2015 06:26 AM
