boost controllers
Old Feb 9, 2005 | 05:55 PM
gus's Avatar
gus
Default boost controllers
has anyone got one fitted to a rs turbo?
i just got one and was wondering what boost you run in different gears?
if yours does this that is (or do they all do that?)
Old Feb 9, 2005 | 06:03 PM
Ish's Avatar
Ish
not all boost controllers have a gear selectable boost facility!
Old Feb 9, 2005 | 06:05 PM
gus's Avatar
gus
Old Feb 9, 2005 | 06:06 PM
gus's Avatar
gus
its the e - boost i have so anyone using that then
Old Feb 9, 2005 | 06:09 PM
RANJ's Avatar
RANJ
madrod uses eboost
yum360 uses eboost
sunny uses eboost
madade-uses eboost
mark shead on evo - uses eboost
they are 1 othe best boost controllers if not the best on the market
Old Feb 9, 2005 | 06:38 PM
simhopper's Avatar
simhopper
apexi avcr allows gear select function has loads of other features too i did look at the eboost when choosing one but found the apexi to be a better all rounder
Old Feb 10, 2005 | 05:01 AM
gus's Avatar
gus
so what boost do you run in different gears then? mainly the fwd bricade really
Old Feb 10, 2005 | 05:23 AM
c6mby's Avatar
c6mby
oh i want one
Old Feb 10, 2005 | 11:45 AM
gus's Avatar
gus
Old Feb 10, 2005 | 11:56 AM
CraigN's Avatar
CraigN
i think you need a speed sensor to be able to do the different boost in diff gear thing, maybe wrong as i dont see how u coudl fit one to some cossies.
Old Feb 10, 2005 | 12:00 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Out of interest, how does the boost controller know what gear you're in ? Would it be fooled if you shifted from say 3rd to fifth, or 4th to 2nd ? Just curious really.
Old Feb 10, 2005 | 12:14 PM
rsnissan's Avatar
rsnissan
uses RPM V's speed normally
Old Feb 10, 2005 | 12:17 PM
CraigN's Avatar
CraigN
thus why i said you need a speed sensor
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
