wiring twin fans
hi does anybody no how to wire twin fans in. i have connected them to the exsiting wiring 2 fans into 1 connector and the wiring is gettin hot thanks
i used the normal temp switch to run 2 relays running each fan with a supply direct from the battery...
use the normal loom to switch the fans on and off via 2 seperate fused relays ..
run the +12 direct from the battery .. pretty sure the temp switch is -ve switched on escorts
Steve Escos
01-10-2015 06:57 AM
