Castrol GTX high milage 10/40
just finding my feet
its a bit thicker and so the engine dont loose as much oil
a mate of mine used it when he was told to use oil that was too thin and he done his valve stem steals in and that helped the smoking hes car used to do
i used it in me 1300 escort too as that started using alot of oil
std ford oil for your car
or maybe sythetic if its a good spec/ recent ish rebuild.
Its not coz its too thick for the oil seals Ginge! Its just cheap low spec oil!
Alex
Alex
no im sure its due to how it acts when up to temp, its not as reliable, but i also was under the impresion that the thicker oils are bad for the turbo , could be wrong, dont mind if i am either
but i do know it worked wonders on me mates 8v dhoc 2.0 sierra and my 1300 hcs escort too
I'm here, what's the question?
Model, year, engine etc. Any mods and type of use would help too!
Simon
PS: Couldn't find a phonebox - Sorry for delay
Simon
88spec, 99k on the clock,standard car,new oilpump and camshaft (both standard) fitted last year. Not a lot of miles but driven hard when it is
fooking horrible stuff, wouldnt use it in my V6. apparently the same as the old GTX but that is bollox, run's hot I found and breaks down quicker than other oils.
Rob
Rob
i used to run GTX in my V6 all the time with no issues (regular 3k oil change) but when they switched to this newer stuff, it would break down very quickly i found. I cant remember if I had the oil cooler then or not mind. but i noticed a difference in longtivity between the old and new blend.
Rob
Rob
Drop me an email and I'll send you a price list with some options:
sales@opieoils.co.uk
OR, look at the prices posted here and then ask me questions.
https://passionford.com/forum/viewtopic.php?t=101561
Cheers,
Simon
Cheers,
Simon
07-10-2015 12:56 PM
