p8
Old May 19, 2011 | 09:47 PM
fezzajsy's Avatar
fezzajsy
Default p8
anyone know the chip its got?whats the diffrence between an l8 and p8.am planning to run a t4 and 8greens,lower compression,closed loop etc
Old May 19, 2011 | 11:55 PM
Karl's Avatar
Karl
Norris Motorsport
That is a L8 ecu with pectel board fitted. It is impossible to say what the chip is mapped for without examining the file itself.
In order to run 8 injectors you will require modifications to the ecu. To the best of my knowledge no 8 injector pectel software exists for the L8 that uses lambda strategy.
Old May 20, 2011 | 01:27 AM
axelriet's Avatar
axelriet
Just reading the label says...
Group A with 34mm intake restricor, Bosch 403 grey injectors, Marelli APS05 3 bar map sensor, Water injection on pin 12.
Three crucial things we don't know: the engine's compression ratio, the fuel (not just RON but actual fuel it was mapped with) and the fuel pressure.
The chip is unreadable thanks to the Pectel babyboard, no one knows every details besides the developer who created it, all I can say is: don't run this.
