Oil breather fittings.
Just trying to order up the last of the bits needed to fit my new engine,
I've got a bailey breather that i want to plumb in breathing from both sides of the block and return to the sump,
so i need a fitting for the the block below the turbo with a 16mm outlet? does anyone know what thread size i need?
also what size pipe is the return to sump? as i need a fitting to screw into my sump.
