ECU memory loss
Hello all, I am v new to this and hoping for a little help !! I have a 2007 1.6 tdci that will not keep it's memory.... So every time you switch it off it drives slow for the first mile relearns and drive super!! Been to a ford specialist who has been stumped and suggested I tried a forum!! Does the ecu have a separate back up battery?? Any ideas to try would be most appreciated !
Thanks George
Thanks George
The ecu doesnt have a seperate battery but does have an seperate permanent supply feed.
I cant help with specifics but I would be checking ALL fuses one at a time with a multimeter in the first instance.
Brakes are fine thanks. All fuses have been checked, the battery was the ford specialist guess! It's just a mystery or the ecu is broken, no fault codes! I will get my multi meter out and check the live feed to the ecu!
Thanks for the suggestions G!
had a poor batt in my car when I first had her every time you start dials would do a full sweep and idle could be lumpy till it learned this was resolved by having a new batt the other thing is you would have a feed called KAP keep alive power this has it own fuse so worth checking that and having that feed wire tested.
As said below (Keep Alive Memory) it should be located in the main fusebox I should think, for something like this to "Stump" them and suggest coming on here is worrying and beyond me!
Martin
Martin
The fuse may not be marked as KAM, do you have a owners handbook, it may show a picture of a engine, look in the fusebox/s and see if there is a violet 2 or 3 amp fuse in one, and what the lid says it is for, what is the picture for it ?
I think you need to establish weather the power to the ecu is actually failing. Certainly sounds like it isn't to me. You sure it isn't just because the engine is cold it isn't running to its full potential?
You could always log a fault code by pulling air flow meter or something to bring the warning light on, plug it back in, then restart the engine. If warning light is still on, then there was power to he ecu, as this fault would have been wiped if power to the ecu was lost.
There is power to the ecu!!! New question ..... Where is the ecu was lead to believe it was behind the glove box!! Anybody got any hints for somebody who is about to find a can of petrol and a lighter!!! Stupid thing is driving me mad and am throwing money at it non stop!!!!!
Thanks George
Thanks George
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
Sep 14, 2015 09:04 PM
