ABS instructions
Old Apr 29, 2011 | 01:06 PM
Baggy's Avatar
Baggy
Default ABS instructions
Hi, newbe here
Anyone know how to get hold of fitting instructions for ABS Motor & Pump Kit for 1988 Sierra 4x4.
Old Apr 29, 2011 | 05:54 PM
Do you mine diagrams to help you with the system?????????
Old May 1, 2011 | 05:46 AM
Baggy's Avatar
Baggy
Hi thanks for your reply.. i have a brand new pump with fitting instruction pamphlet [in German] wondered if there are any special do's or don'ts while fitting it
Old May 1, 2011 | 08:02 AM
dojj's Avatar
dojj
Resident Wrestling Legend
have you got abs already or not
pump swaps are easy, but retro fitting the abs kit is a bit more complicated, expescially if you don't know if you've got the correct assembly for your car or not as they different between left and right handed as well as 2 and 4wd cars
also the loom is stand alone other than the light in the dash and the power feed from the ignition, but the 4wd stuff has extrta relays in the fusebox
Old May 8, 2011 | 10:42 AM
Baggy's Avatar
Baggy
Yea I already have ABS, as the system is 23 years old, buying parts incase of a failure.
The new item is just the pump not the ancillery, so if the pump I have looks identical to the one being replaced it should be fine?
Thank you for you input and time on this issue. Sorry for the delay in replying, new to this site.
Old May 8, 2011 | 11:33 AM
dojj's Avatar
dojj
the pump loking the same and the connections being in the same place and the resivour bottle being on the right side are all good and it will be a straight swap
the early cars had the modulator box thing intergrated into the main pump assembly while the later ones had them on the other side of the engine bay
Old May 9, 2011 | 03:25 PM
Baggy's Avatar
Baggy
thanks again , mine is the later one with that modulator i call it the valve block being seperatley sited, had to replace that a couple of years ago with a 2nd hand one that works fine would love to get my hands on a brand new tho. Had the car 14yrs and it will probably end up being burried with me.
tankybaby66
Feb 6, 2016 02:24 PM
locum8
Oct 1, 2015 01:50 PM
