nut and bolt quick release replacement
Old Apr 16, 2011 | 02:49 PM
rsturbolee's Avatar
rsturbolee
Default nut and bolt quick release replacement
i know theres r clips about etc but id like some advice
basicly i have some ramps that fold in the middle, theres a 17mm head bot and nut on each side about 2 inches in length which joins the two sections
in an ideal world if i wanted to quickly split and reasemble the ramps it would be a pain
looking for ideas.........
Old Apr 16, 2011 | 03:18 PM
xrmalin's Avatar
xrmalin
We use alot of pip pins at work which are a straight pinned shaft with a ball bearing that pops out to secure it in place. I couldnt tell you where we get them from though as i dont have anything to do with that but it might be worth a google search for the right size you need
mark.
Old Apr 16, 2011 | 03:22 PM
piccie would make it easier to work out.
Old Apr 16, 2011 | 03:37 PM
dojj's Avatar
dojj
Resident Wrestling Legend
use a pin? like they do on towing hitches?
Old Apr 16, 2011 | 04:00 PM
rsturbolee's Avatar
rsturbolee
thanks ill try google pip pin in a min
towing hitch pin?
oh and bare in mine it will have to be thick and strong, dunno what a 17mm head bolts thread size is but i bet it a good 12mm or so
Old Apr 16, 2011 | 04:09 PM
focusv8's Avatar
focusv8
10mm. outer diameter.
Hartwell pins described above, probably not good on a hole that's likey to wear.
http://shop.ebay.co.uk/?_from=R40&_trksid=p5197.m570.l1313&_nkw=hartwell+ pin+&_sacat=See-All-Categories
This is what you want,
Bow tie locking cotter pin;
http://www.pivotpins.com/catalog/bow_tie.shtml
Old Apr 16, 2011 | 04:38 PM
rsturbolee's Avatar
rsturbolee
that bow tie thing might be right !
maybe this will help
Old Apr 16, 2011 | 05:01 PM
dojj's Avatar
dojj
towing hitch pin?
http://cgi.ebay.co.uk/Ball-and-pin-t...item483fec7db5
the pin in the middle that can be released
much like the other pins but these ones may be more suitable as they are designed with heafty shifting in mind
Old Apr 16, 2011 | 06:22 PM
rsturbolee's Avatar
rsturbolee
its a good idea mate although i think they will be far too long, couple inches i wrekn is all i need, to long and cars will be going over it
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
IanC
Sep 5, 2015 09:38 PM
hopper350
Sep 4, 2015 12:53 AM
