brake disc help..
Old Apr 14, 2011 | 08:14 PM
KW-rscos's Avatar
KW-rscos
Default brake disc help..
Got my MOT coming up and I am going to fail due to the vibration in the front brakes.
I currently have a 285/24mm hi-spec billet 4 conversion, but want to swap to MK3 mondeo calipers and ST170 grooved 300mm discs, however, I will not be able to get that sorted before the MOT, so can anybody tell me what car these discs originally came from so I can buy a cheap pair until I can sort out the mondy/foci ones.
They are 285mm by 24mm vented, with a ford 4 stud pattern.
I have already sussed the pads as dp143 vovlo 98mmx60x16 and managed to get a set for £20.
any help much appreciated.
Old Apr 15, 2011 | 07:06 PM
KW-rscos's Avatar
KW-rscos
anyone?
Old Apr 15, 2011 | 07:20 PM
mk2 cossie's Avatar
mk2 cossie
what motor is this on? and how bad is the vibration?
if its only a slight vibration, its a pass and advise for the MOT
Old Apr 15, 2011 | 07:50 PM
KW-rscos's Avatar
KW-rscos
its on my 98 escort gti, but unfortunately the vibration is too bad to pass :S
Old Apr 15, 2011 | 07:55 PM
mk2 cossie's Avatar
mk2 cossie
well, if its tested on the brake rollers it might not even get noticed
be suprised whats ok on those but poor up the road
Old Apr 15, 2011 | 08:27 PM
In all likleyhood, and having known Geoff for over 20 years, they will be actually 283mm cossie 2wd discs, in the very unlikely event they really are 285mm, 283mm would be fine anyway, so long as offset is ok.
Nov 1, 2015 06:53 PM
locum8
Oct 1, 2015 01:50 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
